Canadian 2.5RS
- Sep 12, 2006
Is there really a performance difference between the si-120 and the si-128? Does anyone know of a review that puts them up against each other? The 120 weighs in at 400g while the 128 weighs in at 510g. If there is no significant difference in heat dissapation, shouldn't I just go for the lighter one (I would rather have less stress on the mobo if there isnt a difference)? or is weight even a factor I should consider in my choice since these are reletively light heatsinks?
