Shuttle's motherboard !!
sometimes you might get lucky and find one on their site or on ebay.
scottatwittenberg said:
shuttles and the other computers the same size are all proprietary.. the smallest common form factor is m-atx.. those fit in things like the x-qpack and the antec aria..
if you really want small, look here. http://www.cappuccinopc.com/default.asp
oh, look for epia boards too.. i think they are all integrated processors though..
http://www.epiacenter.com/modules.php?name=Content&pa=showpage&pid=39
see if that works actually.. it might put you in the right direction
hey, ty very much, after i went thru the page, i think the M/B i'm looking for is for CubePC !!
and i tried on Ebay.....didn't work very well, most of the cubePC on ebay are cases and M/B included !
some of them look okay, but i found my own case which looks alot more better :p
i'm also looking for the M/B that can use AMDs Cpu, since the one u posted was for VIA and Pentium
Actually the antec aria has undergone 2 revisions. I purchased one last year and it ran pretty hot. I just purchased another one yesterday and to my surprise when I opened the box it was the revised Antec Aria it has better cooling and a quieter power supply and fan also came with revised instruction manual that is much better than the first. This is my case of choice. You can choose a motherboard of your liking as long as its micro atx which is better than getting stuck with a proprietory board. I also have 2 of the shuttle pcs , i purchsed the kits and built the systems no complaints shuttles are very nice and I have no issues with heat. (using the g3 or g4 series shuttles) I have the antec aria with an amd 64 3400 cpu and 2 250gb sata hard drives and it runs at a good temp (I had to put a blowhole and fan on the left side of the case)..
ty for ur advise, do u still remember the aria's model number ?
or it's just "aria" ? cause u said there is a revised version ?_? and i only see "aria" online
so i'm just wondering ~ i might get this one OR
http://www.newegg.com/Product/Product.asp?Item=N82E16811144109
i'm still thinking, i don't know which one would be better, but u have aria already, i might just get the same one then
You will have to call and ask. I went to the store and checked. Make sure you are getting the newest one. You will know this by lookng at the top. On the new one the top has a cutout on the rear top over the power supply that is vented like a window with mesh on it. if not you can get one at www.microcenter.com look for store locations or just order it online. let me know how it works.
hamsteryang said:
i think i'm looking for amd 939 or pentium socket 775 or 478
I have a Socket 478 (Pentium 4) motherboard that will fit in a Shuttle, and I'd sell it to you. How's $60 sound?
-SEAL
