Shuttle xpc system options.
topslop1
Looking for a mid to high end shuttle small case solution ( shuttle xpc ? right? ) for gaming. Probably going to do an AMD XP or AMD 64 if it's cheap enough. What are the current choices and what are the pros and cons. How much would the total system cost be? Looking for something under $1300 but would still like to check out the price of an AMD 64 even if it's a little more. What are the precautions to working with a shuttle xpc? Is it different than building a regular system? Is there any potential for overclockability? Give me a piece of your knolwedge on this, thanks all.
This is one I put together, hoping to have the funds available in a few months to be able to actually buy it. The cost of this is ~$2000, depending on whats on sale at the time.
My Dream Lanbox
Enjoy.
I would be able to make various cuts on that price that should bring it down to what I need it to be. That is an amazing box at a very good price. I'm impressed with it to say the least - you have very good taste :D
Things I'll probably do is throw a smaller harddrive in that, I don't need a dvdrw so I can just get a cdrw. I can also get an amd 64 bit 3000+ for only $200 or so. If I get a 3000+ it has half of the cache. Will it make a difference between 512 k cache and 1mb of cache?
I can also do without the XT although it's very nice :) A 9800 pro would be sufficent. I'd have to check out the prices on the ram, maybe I'd just go for 512mb of high quality ram and then just upgrade when I had the money.
I'll have to go through and set up my own with yours as a solid base.
Also - do these things have any overclocking potential? Or is overclocking in these just not reccomended or not sufficent enough to bother with?
Thanks.
Good review, I can't beleive I stepped over that without reading. I don't think I'll be doing much if any overclocking with this board. What kind of active cooling are they using for their ram in that review? That system seems like it's among the top performers today and it's quite small. I'm worried at the memory bandwith differences between that and the P4 in the sandra tests however. Are p4's better at memory bandwith to begin with? Is it a big difference?
I don't think their using active cooling for the ram. Difference with the memory bandwith is due to the P4 having dual channel memory where the 754 Athlon 64 is single channel with that in mind I thinks its incredible that this little box (and the Athlon 64) can keep up with and even beat a 3.2ghz P4. The only cooling I'm aware of with the little Shuttles is one 80mm fan for an exhaust (and I think one in the PSU) their Heat pipe cooling system is just so cool.
Shuttle SN45G
AMD Barton 2500+
Corsair 512MB 3200C2PT
WD 800JB
Tyan 9800 Pro-M
Logitech Wireless Elite (MX700)
LiteOn DVD ROM
Samsung 153B
Done
$1,234.99
I've already got a 21'' sony to work for me but I've pieced my own system together pretty much.
Shuttle SN85G4
Amd 3200+ 64
9800 XT
512mb Mushkin pc 3500 Black level 2
80 gig maxtor 8mb cache
52x cdrw cd
Audigy 2
I've already got the aud 2, I can get the cd drive local for $10 - $20 depending on sales and I can get an on sale harddrive for $50 - $60 with about the maxtor's specs. This is going to end up costing me about $1200 - $1300 out of pocket and it's a sweet system. I was figuring going with the 9800 pro and a gig of mushkin but sometimes you just gotta be crazy, and I can get another 512 in the future.
I'm staying with an ide. My main deceision for going with a 3200+ is the extra cache that they have on it. I don't know if it's stupid that I go for it or if it's just a mental thing or if it'll make a difference somewhere sometime but I really want to go for it. SATA really doesn't have much more in speed than an ide from what I've seen.
