Shuttle XPC stock fan grill mod
Hi, ran across the video card mod by jewball, quite impressed, i dont have that impressive of a video card yet, however i have a really hot proccessor, the Intel Pentium 4 3.0E prescott, prescotts are some very hot proccessors, and should not be used w/o some additional cooling options in the shuttle, from first glance i can see that the stock shuttle fan grill on the back not only restricts air flow, but it also creates alot of noise, not cool, so i decided i would just simply cut away the old one, and attach a classic 80mm fan grill
Pictures:
improve airflow and reduce noise at the same time.. hit two birds with one stone :D. looks like a good, clean cut, nice work!
Thanx :D anyone with a xpc knows what i mean that grill they put on the back was obviously not intended to ever have air blowing through it...
Just got my shuttle, so I should probably see if its stable and running smoothly before voiding my warrenty. :eek: But im planning on doing this exact mod, what kind of temp drops did you get? Nice work very clean!
about 5 degrees in idle, and about 4 degrees in load, but more than the temp drop is the noise reduction, when operating the shuttle cpu fan at full, or when the computer is under load under smart fan, it can become quite loud and quite annoying, thus this mod, to improve cooling you will need forced air intake into ur shuttle, forced air outake is simply not enough, remeber the shuttle cpu fan is doing both jobs, its pulling air in and pushing it out, idealy you should possibly mod ur side pannel to include a 60mm fan or even a 80mm, to get some forced air intake
Atleast in the model I have (SB61G2V2, which I believe is the one in the pictures?) theres basically no space for a fan on either side up near the front plate, one side is blocked by most GFX cards and the other side is blocked by the power supply cables. I could see someone being able to get a 60mm on the side with the PSU unit but I dont think I could do it and make it decent looking as well. :(
i dunno, im pretty sure either a 80, or more confortably a 60mm, will fit on the graphix card side, i dunno how long/ big urs is, but if u cut the hole very carefully, then used large metal mesh on the inside to give it that, (ur not allowed inside) look, get a small decent 60mm fan cover, since the shuttle cover bends u can bend it flappy style to get it on and off, even less so depending on the thickness of your fan
