Shuttle XPC SB95P Pentium 4
Yep. Especially cuz of that 350w psu. Ppl can run X800 XTs on those 250s so you should be fine.
Was able to check on pricewatch and found it at these two places.
http://www.censuspc.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=SB95PV2
http://www.ajump.com/ajump/product.asp?pf%5Fid=4440123&dept%5Fid=5511
Also what about this one.
http://www.ajump.com/ajump/product.asp?dept%5Fid=5511&pf%5Fid=3040123&sku=99%2D99%2D99%2D99%2D99%2D3040123
It's got built in video but also has a 16x PCIe slot, also it supports DDR instead of the spendy DDR2. Should I spend the extra money and get the
SB95P or spend less and get the SB81P?
Do you guys think its safe to order from either one of those?
