Shuttle XPC HELP HELP HELP
ALYNCH75
:confused: :confused: Hey I just got a shuttle SNG 41 and I flashed it with the wrong BiOS how do I get it back. I can no longer boot my machine. THe fans are spining the computer powers up but I don't see anything on the screen. I think i flashed it with the sng45 bios. What should I do? I need help before my wife finds out what I did to her new system.
This happened to me a while back...I think I had to shorten the CMOS jumper in order to
get it to boot up again. Hope this helps :)
Try resetting the CMOS would be easiest step.
If not, download the CORRECT BIOS from a different computer and follow the procedure to installing it.
If that doesn't work, you will have no choice but to RMA the system back.
