Shuttle XPC HD brackets; where to get?
The hd brackets in my shuttles are part of the same assembly that holds the optical drive. That is a pretty big piece to lose and I doubt you are going to be able to find a replacement for it... Shuttle is not good with replacement parts especially for their older models.
You might try the FS forum over at sfftech.com. I've had good luck sourcing odds and ends for shuttles over there.
Does the OP still need this part? I think I can help you....I have a complete XPC case at home that has a dead mobo....send me a PM or email and I can check it out tonight, but it has the cage and everything in it still...
