Shuttle XP17 V. XP17BG3V2 worth it?
If this is just for lan parties, you might want to look at that Dell 17" in the HotDeals section. I mean if your only using it part time you might as well save $100+ and get that.
I have the 2005fpw which I guess has pretty much the same specs (could be wrong) and it looks great. I was going to buy that to have a second monitor but I really dont need one.
fixed the links. and it has to travel well. which is why i am shying away from less sturdy models.
you should try to search for some reviews. Just because it has a lower reponse time doesnt always mean that its a better monitor especially for gaming
the problem is there aren't many reviews at all. All two of them say they are great mionitors but neither compares the two to each other.
