Shuttle SS56G Will not turn on...
Howdy, putting together my buddys new comp right now, got everything in, everything is seated right, plug it in, hit the power button....nothing. The motherboard light is on, but the power switch does nothing. I cant begin to tell you how hectic building this computer has been, went through two RMAs cause first he ordered the wrong vid card, then we found out his first shuttle was not Prescott compatible, this is the Shuttle SS56G V2, so its Prescott compatible, he just bought this barebones today from Best Buy, brought it over, and nothing. Any ideas? Any help is greatly appreciated, this is turning out to be the most frustrating build Ive done :(
EDIT:
Sepcs:
Shuttle SS56G v2
2.4a Prescott core.
512mb 3200 Corsair Value Select.
6800 le
16x dvd+r/rw drive.
Well the first thing that comes to mind is something I did which is not plugging in the Jumpers right...check to see if you have the power switch cables/rest cables etc etc set up correctly. Perhaps you flip-flopped them all.
Yea thought of that too, but Shuttles come with everything factory plugged, double checked anyway of couse and everything was fine. It uses small ribbon cables oppopsed to a bunch of jumpers.
Found the problem, the Video card im guessin is incompatible with the agp slot, wasnt there something about a certain voltage 6800 wouldnt work with a certain voltage slot or somethin?
