heliotrope
- Feb 27, 2005
I'm having trouble ensuring I have my CPU sensors set up correct.
first i installed MBM5, but it reported the CPU temp (31C) to be cooler than the case temperature (37C)!
so i tried SpeedFan 4.22, which works somewhat better, but still seems to have problems. It reports my CPU running at 40-44C - which is believable, as I have the fan speed pretty low on the system.
but, there are lots of other sensors, some of which are reading in the 36-38C range, which might also be my CPU.
and to top it off, when I quick restart the system and go into bios to see what the bios reported temps are, it usually gives me 21-22C for the CPU temp, and about 33C for the case temp. doesn't make sense, unless that report is backwards (as i suspect)
Does anyone know what addresses are the correct ones for the CPU, etc on in an SN95G5? Or maybe a piece of software that would better detect temps?
