I just purchased a new stick of RAM for my SN45GV2, and was fiddling around in the BIOS attempting to set a 1:1 ratio between the RAM and the CPU FSB. I probably exceeded the capabilities of my Athlon 2400, and the system refused to POST after I saved my changes. I used the BIOS reset jumper, and was srprised to see that the system still doesn't boot. This was several hours ago.
I have now stripped the system down to nothing but a GeForce 2 GTS, my old RAM, and a keyboard (and the CPU, of course). No drives or anything else. It still won't even show me the POST screen. In desperation, I just pulled the CPU, RAM, and Video out of the system and turned it on. There's no beep codes. There should really be beep codes at this point, right?
I'm going to assume that the motherboard is dead. The issue is, what would have killed it? I was trying to set an FSB of 166, well within the range of the chipset. Even if my clocks were way off, the BIOS reset should have fixed this. Is there any way to recover at this point? The SN45 is barely 3 months old.
