Shuttle SN41G2v3 Compatibility w/PF31 Case Modding Kit?
Nostram
Is the Shuttle SN41G2v3 compatible with the PF31 Dusk/Dawn Case Modding Kit? The product summary chart here shows the SN41G2 as not being compatible but says nothing about the SN41G2v3. (Or is there a difference?) With what I know of the shuttle systems (being very very little) I would have stopped there and assumed that it was not compatible. However I also found on the Shuttle Europe page a similar list that claims the PF31 Kit IS compatible with the SN41G2v3.
Now from what i've seen of the PF31 kit front panel at the Shuttle Europe - Showroom page and then looking back at the SN41G2v3 front panel the SN41G2v3 has two buttons or inputs to the left of the reset and power button that aren't on the PF31 Mod. Of course there are also the round buttons to consider instead of the square and rectangular ones shown on the kid.
Does anyone know where I can get a definitive answer to this? If it's a non compatible issue is there a simple way to just convert the front panel of the SN41G2v3 system to work? If not is there another dual headed nVidia unit that would be compatible?
Many thanks in advance.
-Nostram
the fronts are different.. that kit is for a "G" case... the sn41G2v3 is a "G2" case...
that is only based on the picture.. but still.. they wouldn't show a picture of something different than what they are selling...
