Shuttle SN27P2 on the way
alphaone
I just ordered the SN27P2 from ZZF with a 4600+, 7900GT KO, 2gigs of ram, and the rest of the trimmings. It will be here tomorrow! I will let you know how it is in a mini review and of course pics as I put it together :)
Until then...
Ok here I go with my mini review.
From the start I was impressed by the thing's good looks and solid construction. All the edges were rounded and despite it's small size there was plenty of space to work. I had no trouble installing the cpu and the ram. I had some difficulty getting the dvd burner installed though. It had to be at a precise distance from the front of the case so that it wouldn't be riding up against the button pusher. After some fiddling I figured it out. Installing the HD was easy. Getting my 7900GT in was a sort of a challenge. But after some trying interesting positions I was able to squeeze it in. Total time to put it together: about 1.5 hours, but I was taking my time.
It was easy to get it set up in running. In fact I'm still doing that. The only beef I have with it so far is the audio. There's just not enough shielding on the line. When you're listening to music or there's any other sound on the line I can't tell that there's any noise there. But when there's silence, there's lots of noise. That kind of squeeky crackily noise. On my old pc that had the nvidia soundstorm I would get some slight noise during heavy disk activity, but that was it. It's not a big problem. Just a little annoying. It seems very fast so far and it's very quiet.
More later.
Nice man, thanks for the pics.
I'm personally waiting for the SK22G2 to hit the market. It's only comin' with a 200W PSU I think...but for someone who doesn't need the fastest hardware out there it'll still do quite well, AM2 support, 4GB of ram, PCI-E and PCI for an X-FI...only downside as I see it is the PSU. Have to wait and see if the PSU can be swapped out for a larger one from shuttle...but the SK22G2 is what I'd see myself going with...as I don't NEED the fastest stuff out there, and I've always loved the G2 chassis.
Keep us updated though, I've ran across some issues with USB keyboards over at sudhian where the system will not recognize some keyboards at all, and will boot ridiculously slow with others.
Hopefully the SK22G2 will launch with a relatively small amount of quirks and I can seriously look at it for a daily rig down the road.
Me too. It's unnoticeable if there's any sound on the line, but if there's silence it's there and very annoying.
Also, it only happenes when my headphones are plugged into the front port. If I plug into the back there's no sound but the sound is very tinny. It's really odd.
Excellent. I'm actually looking into this SFF right now. How are the temperatures? Is it really crammed in there? Have you tried any overclocking yet? :)
Temperatures are fine. Right now the cpu is at 43 degrees and yesterday when I was trying some games it was up to 48. Haven't tried overclocking yet, but I will eventually. It's actually pretty roomy inside the case, for its size at least.
Nice system. I may have to save some cash for one.
Yeah my only problem with it is the sound, because I don't have space for a good sound card (tv tuner in the pci slot). I can bypass the internal audio by using my old usb speakers, but that kind of defeats the purpose of having these nice headphones. I wish someone would come out with a good and affordable usb soundcard. Does anyone know of any?
