Shuttle SK83G
Novensu
Guys, has anyone seen a bay cooler that will fit into a 3.5 floppy drive bay? I searched google and didn't find much. I was loooking for one with a front intake as to pull in cool air. If I can't find one I was thinking of a slot blower and trying to mod it. Any ideas?
Thanks,
Novensu
unfortuinately no, only 5.25".
why is this? your sk83 not cooling?
whats ur setup?
My setup is:
Athlon 64 3200+
1GB Dual Channel Ram
Radeon 9800 Pro
80Gb Drive
4x DVD-RW
It is cooling better that I originally thought. I have readjusted the fan speeds in the bios. I was just worried that it was too hot.
Thanks for the reply,
Novensu
Well the shuttles use the vent holes down the sides for main cooling. It seems to work pretty well to try and cool everything in the case. There are some issues that Ive heard of with video cards, but thats because the video hsf is so close to the side of the case the fan gets a bit starved of air.
With shuttles you kindof just have to get used to a hot box. These things get physically warm to the touch in spots (on the outside) under normal use. All exhaust air is realy warm because it goes through the cpu hsf or psu first. Id suggest using one of the bios veriable settings. They work realy well.
