I have an older SK41G with 512 of ram but I need to upgrade the ram as my system is running sluggish, can someone recomend me the best ram to get for this system. Im hoping for 1gig not sure if 2 will work with this. Thanks
Unless you are doing some intensive editing work, 2 gigs will be a waste as it won't match the rest of your system. An easy recommendation for ram is Crucial.
If your system is sluggis I recocommend a fresh instal of your OS if you haven't done so in the past year.
