Shuttle sd32g2 & X1800xt
Just wondered, will an x1800xt fit into a Shuttle SD32G2? I have looked a the 'Will it fit' FAQ, but wasn't sure if the 'yes' for an X1800AIO covered the XT.
Also, would one fit with the Zalman vf900 fitted?
Thanks for any help,
Felix
Not without mods to the cover and chasis - as the PCI-E slot is on the outside (single slot).
I have modded several Shuttle's to work with dual slot coolers and they actually perform very well ;)
