Shuttle SA76G2 owners - need assist!
dderidex
First question is - are you having the same problem I am with 'sleep mode' on these?
Before I had mine, I had recommended builds for co-workers based on them (for the combination of reasonably priced AMD procs, and ridiculously tiny form factor). All is generally well, except they apparently were having issues with 'sleep mode' - the boxes would not come back from it. They simply disabled power save modes, and that was that, but...
...well, I'd rather not. Leaving a PC running 24/7 is a sure way to get it rather thickly clogged with dust and such over time!
ANYWAY, I'm running Windows 7 Ultimate 64-bit, paired with an AMD Phenom II 945, OCZ Vertex SSD and WD 'Black' HDD as drives, Radeon HD 4830, and Creative X-Fi Xtreme Gamer. Catalyst 10.1 drivers, and up-to-date on everything else, too.
For short 'sleep' durations (we walked away for a bit), it generally comes back alright. This obviously makes troubleshooting this issue difficult. For long sleep durations (overnight, for example), it never returns.
Computer LOOKS the same, all external lights off, USB peripherals off, only the mobo lights lit up and no fans running...and when you hit the power button to turn it on, indeed, the system ramps up the fans, power light comes on, etc...but it never boots. Doesn't even POST. Monitor stays in it's 'idle flashing' mode.
If I then hit the 'reset' button, and dig through the Windows event log, I can find notes indicating that:
The previous system shutdown at 2:46:47 AM on ‎1/‎30/‎2010 was unexpected.
...and...
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
(Note that this is when it first boots after being in a 'failed sleep' state - the time the logs indicate of the 'previous system shutdown' are pretty close to when I would have expected it to enter 'sleep' mode).
Ideas? Anybody else even seeing this?
I can't provide any solution, but I do want to voice that the SN78SH7 with Athlon II 250 and Win 7 64-bit suffers from similar symptoms of not properly waking up after long sleep.
...and...
Check the Power options?
What are they set at?
Out of curiosity:
- What video card drivers are you using?
- Is it a video card that needs an external power adapter? (Trying to figure out if this is something specific to the Shuttle's external PCI-E power or something...)
What are you looking for, in particular? (There are a LOT of options)
High-level mode I have it set to is 'Balanced', but with a few tweaks (hibernation disabled, hard drive 'turn off' I've disabled, etc).
BTW - this, specific, issue (system not returning from sleep at all) appears to be resolved for me.
What it took (I think) is two things:
  • Downloading the latest BIOS for the system - SA76U10F
  • Downloading and installing the driver set that included the ATI 'Southbridge' driver (strangely not included in the 'entire Catalyst package', even if you select the right chipsets. It appears to always be a standalone driver?), which, curiously enough, includes an updated 'Northbridge' driver.
BTW - to get the right 'Southbridge' drivers, you need to go to "game.amd.com", driver's section.
Path to take is:
Motherboard/Integrated Video Drivers ---> Individual Drivers (Motherboard/Chipset) ---> South Bridge Driver
