We have the 80mm going out the back, modded to a 120mm mounted externally..
BUT
has anyone put a 40mm (probably the biggest that would fit) on either side of the case just behind the faceplate tward thebottom of the cover..
lemme try to describe...
one fan+grill on the left side of the case (faceing it), tward the front probably even with the memory slot, as intake... and one on the same spot on the other side of the case, also as intake?
they dont have to be huge, due to space or lack thereof..
wondering if this is possible and if it would look ok..
would improve airflow some? or would it just plain look ugly..
BUT
