Well, I recently decided to take my old Shuttle PC, currently gutted, and set it up as a "home-theater" PC. Everything else is working fine, but for the longest time I couldn't get the onboard sound to work. Previously, I hadn't been able to find the drivers for the mainboard audio, but today I actually found them and got them installed. Now, I was hoping this would fix the problem, but it only partially has.
I get sound, but it's extremely quiet. When I say quiet, I mean that my speakers are at full volume and the computer volumes are all (I think) cranked up, and it sounds as if I'm holding a pair of headphones about 6-12" away from my head. Now, I know the speakers are not the culprit, as they work perfectly well with my iPod.
If anyone has any insight as far as how to fix the problem, I would be very grateful. The PC isn't really a Shuttle anymore, so the only really information necessary would be, I'm guessing, the motherboard. The model number is FS56 made by Shuttle. I got the audio drivers supposedly for this motherboard here, but the BIOS they have there didn't work in WinFlash. It said "Please supply correct BIOS" or something similar. I installed both of the audio drivers on that page as well.
Thanks in advance,
Alex
Edit: Just to add, the sound works perfectly fine with a sound card, but I'm using the one from my main PC which I can't really remove full-time. So I think it can definitely be isolated as the onboard.
Thanks in advance,
Alex
