Ok, my SN45Gv2 won't start up anymore. It's definitely the motherboard, I've tested everything else and it all works. For over a year, I had a 2500xp-m running at 8x200@1.25v. The mobo battery is dead so everytime the system gets unplugged, I need to reset all the settings. Not really a big deal.
I recently had to do just this, but when I rebooted nothing came on screen. Reboot again, still nothing. I figured it was just one setting that it didn't like, so I clear the cmos (both with the jumper, and unplugging the system). Still nothing.
When the system is off, but plugged in, the mobo led is on. When I press the power button, the front blue led comes on for a second, then they both turn off; but the system is still running; the fans are on, the hard drive is spinning but not reading, I can open and close the cd tray, but nothing on screen.
The cpu, ram, hd and video card all work in another system. It can only be one thing. And I've spoken to someone else with a very similar problem and he could only rma the board.
I doubt I will be able to now that it's 2+ years old. Would anyone with some experience with this have any advice or ideas?
Thanks.
Thanks.
