shuttle nforece 2 ultra. your thoughts?
I've got one- Excellent board for the price, and quite overclockable- the only drawback is the 2.7v Dimm Maximum, however, with my Sammy 333, I can take it 1:1 up to a 460FSB @ 2.7v. vCore adjustments are allowed up to about 2.2v.
Full multiplier adjustments are available, etc etc..... Expect Szandor to check in on this topic shortly.... (he is always plugging this board... along with me...)
Can't miss a plug for my AN35N Ultra!
Schro sums it up nicely!
For under $70.00 I can't think of a better no frills MoBo. Its fast, stable and very forgiving. Unmodded it'll run 220-230FSB with quality RAM, HSF and PSU. Modded it'll run 230-250FSB.
Mine can run 220FSB x 11 = 2.42Ghz on air w\ XP1700+ JIUHB DLT3C & 2 x 256mb Buffalo\Winbond CH-5 PC3200 - 24hrs Prime & 12hrs Memtest stable. I'm working on 2.53Ghz currently though the lack of higher VDimm will probably keep me from getting Prime stable. Though I have run 166FSB x 15 = 2.51Ghz also Prime and Memtest stable.
I'd suggest getting quality RAM like the Buffalo, Corsair XMS, Mushkin, OCZ
A minimum of 350watt PSU with at least 15amps on 12V rail & 3.3V + 5.0V output of ~200watts minimum, Fortron\Sparkle or Antec are recommended.
A good HSF - SLK series, V-11 or V-12, the ALX-800 is decent as well.
Check out this thread from over @OC Forums for some stats some of us have collected on our AN35N Ultras using different CPUs, RAM and dual and single channel set-ups. I'm known as Balrog at OC so give me a yell if you have any further questions.
Regards, Szandor\Balrog
http://www.ocforums.com/showthread.php?threadid=267160
nice price (newegg.com I highly recommend -excellent prices/low shipping fees always)
excellent chipset.
I have heard good overclocks with this board ( do much better than what I get with my limited biostar)
My only concern is that many shuttle (if not all) boards are made by ECS... erm, ECS isnt what you'd call Abit/Asus/Epox quality... they are low end (but not as bad as say PC Chips)
That is my only concern, but with that price and buying from Newegg eases that concern a good bit...
ECS does manufactur the boards, but to Shuttle's specs. This allows for a quality board to come from ECS's factories- the ECS/PCChips branded boards cut further corners that are not shaved by shuttle's engineers...
Basically, for example, I have terrible handwriting, but if I was paid to write in beautiful handwriting for a specific job, I could do it... Same for ECS- they CAN make good boards, they just don't typically choose to do it (unless someone offers thema fistful of money)
200FSB x 12.5 = 2.50Ghz now Prime and Memtest stable!
218 x 11.5 = 2.51Ghz now working!
And the MoBos Blue! :D
Ahhhhh! Life is good!
Regards, Szandor
Rock solid, great overclocker. I miss the SATA and lack of soundstorm though. Overall, I love it to death.
Exactly right.
These boards use three phase VRM's, quality capacitors and a full four PCB layers, not like an ECS board.
Anyway, this motherboard is the best entry-level athlon board availible IMO. I have one, it's rock solid (prime95, memtest, gaming) with my Athlon XP-Mobile overclocked by 500MHz or so ;)
Make sure your power supply has the four pin PIV power connector, because this motherboard needs it. And good thing too, I'm suspicious of boards that don't.
*cough* Blowout special on the egg *cough*
*cough* SHuttle AN35N Ultras for $54 delivered *cough*
:D I still paid $53 for mine..... :D
