Shuttle MN31N thread
Yeah what messed me up was the first few times it booted it came up with 2500+.
I was braindead from last night and it occurred to me at work where the problem probably was.
Another question: Has anyone setup Motherboard Monitor? What mainboard did you use? The MN31N is not listed.
-Brett
It was doing the same thing on my 1800+ (but for me it wouldn't boot, would say to reseat the processor) Had to manually set my memory as well. Just gave me a reason to overclock a bit. Will do more when I have some better ram.
Did they ever fix the problem w/ giving 128mb of memory to onboard video?
stupid question maybe, but how do you know if your memory is running in dual channel mode? I put the memory in slots 1 & 3 but I don't see anything in the BIOS or when I boot up saying dual channel. btw I have 2 128 sticks of PC2700 from the same batch, so they should work fine for dual channel.
It just happens automatically upon inserting memory into the correct dimm slots; slots 1 & 2 or in slots 1 & 3.
That's it, you won't be able to view any "Dual channel enabled" in bios or device manager. Sandra may display it though i can't remember.
Ok, I thought I was doing something wrong. At work we have some Intel boards (with Phoenix BIOS I believe) running dual channel and it actually tells you in the BIOS. Figured AWARD did the same thing, but maybe not.
Sposh
Bump
Anybody with any interesting updates? Will hopefully be oc'ing my second mn31n this weekend :) and i'll keep ya's posted.
I was checking out my MN31 last night (just put it into the case) and noticed it has dual integrated video. What kind of resolutions will this thing drive in Windows?
Going to put my first post in this thread, since it's probably where I'll spend my most time...
First, want to say what an excellent forum this is! I've read just about every post in just about every thread, can't find any flaming, and talk about an incredible source of knowlege! You folks are awesome!
Now to the good stuff...I bought a MN31N off ebay, and am chomping at the bit waiting for UPS! It was supposed to be in today, but the snowstorms across the country delayed it until Monday. Bummer, but would rather see the UPS drivers home safe for Christmas than have my new toy early, if it's a choice. I plan to use it with a "leftover" 1800MP chip I have, going to use it to build up a HTPC setup. Not going to overclock or try and tweak the BIOS, although the "hacked" BIOS here looks pretty interesting.
Have a question for those in the know already! I read that using memory in slot 1&3 enables the dual-pipeline, which is a big help if you use the on-board video (which I intend to use). Does it matter if say 256MB was in slot 1, and 512MB was in slot 3? Would that mess up the dual-pipe thing, or would just 512MB be "usable" as dual-piped, the other 256MB as "spare" (for lack of a better term)?
Thanks for any / all help!
The dual-pipe (most people call it dual-channel) mechanism is related to the memory controller, and it relies on equal distributions of memory on each controller. Slot 1 is on one controller, and slots 2 and 3 are on another... so, if you had 512mb in slot 1, you would need 512mb in slots 2 and/or 3 to run in dual-channel mode. You could do this with two 256mb sticks, or one 512mb stick in either slot 2 or 3. I'm afraid it only uses all the memory in dual channel, or none of it, so there is no "spare" non-dual-channel allowed.
However, before you go worrying about that too much, you might consider the fact that although running in dual-channel effectively doubles your maximum memory bandwidth (from 64-bit to 128-bit), the processor cannot handle the increased bandwidth very effectively, so the performance increase is not very great (as in, you wouldn't feel it in real-world apps or games on Athlon XP systems). So... it's really not worth worrying about, and the extra RAM will probably increase your performance far more than being in dual-channel mode.
Also, as far as the hacked BIOS goes... I edited it a little, but was not able to get voltage or multiplier adjustments working. I got as far as talking to the chief tech support guy for Shuttle in America, and he said that all the BIOS work is done in Taiwan, and that he couldn't help me go any further. And, while the chipset is capable of those adjustments, they are far beyond my modest BIOS modding abilities, and so that is basically at a dead end for now. Nonetheless, pin modding works, and the board is still great.
-SEAL
Thanks for answering! It became a moot point after whis weekend's adventures, no matter what memory I tried from my stash-box, I'd get the never-ending XP restart loop if I filled slots 1 and 3. But to be fair to the board, I don't have two "matching" sticks, and I don't want to buy a couple since I have buckets of memory laying around now. Feeling that was probably the issue.
So, I ended up just putting 512 sticks in slots 1 & 2. Works fine now, definately fast enough for what I'm going to use the system for. I'm not going to be gaming on it so don't need the extra performance dual-channel would have provided for the video.
Does anyone know of a manufacturer who makes rounded IDE cables with a longer lenght between the master and slave connectors? If I try to put my second drive on the right side of the cage (looking at the front of the machine), it hits my CPU fan. If I try to put it on the left side, I can't find a cable that reaches from the horizontal (primary) drive to the one hanging! Aargh! Are the IDE "133" cables, the ones with the blue connector where it's supposed to plug into the motherboard directional? If I could use the master connector in the motherboard, the slave connector on the horizontal drive, and the connector that's supposed to go to the motherboard on the hanging drive, it would solve that problem!
dang i just typed a book...sorry
I have to repeat...you guys are awesome!
Now, SEAL, I'm going to need your address. My wife is going to want to pound SOMEONE for me spending as much money as I am on that site! :D
