Shuttle MN31N stability issues
BB Gun
Building a micro system for a teacher friend - no gaming, just web surfing, grading, and a little music lesson recording and light editing.
After looking around, picked the MN31N as the most full featured motherboard, plus shuttle seems to be moving up into a first tier vendor with their shuttle-X systems.
WD 80 GB JB drive, lite-on Combo CDRW/DVD, single 512 MB stick of Corsair select PC3200 RAM, Athlon barton 2500+ Retail version, all in an Antec Minuet Piano Black slimline micro-ATX case and all purchased from Newegg.
When running at 166 MHZ, windows wouldn't even load, got small screen artifacts and repeated memory dumps.
Slowed system down to 133 MHz, and I made it through Windows load, but windows is EXTREMELY unstable, with major screen artifacts.
Swapped RAM to a 256 MB Stick of Mushkin Basic Green which is verified good in another computer, and system instablity continues.
BIOS reports temps ok on processor, so I'm pretty sure HSF is installed ok.
Any ideas before I RMA it?
BB
Most likely the PSU, does it have the P4 12V ATX connector and did you plug it in. It only has 12amps on 12V rail which is borderline for newer MoBos.
I'd trade the memory for 2 x 256mb of Buffalo\Winbond PC3200 as this will allow you to run dual channel to support the onboard video. This is the best use of dual channel as you will see a performance increase of 30-40% by using 2 sticks vs. 1
You might also consider RMAing the case and PSU for one of these
http://www.silentpcreview.com/article146-page1.html
It comes with a sweet Antec 300watt PSU w\ a quiet 120mm fan
I run 2 x MN31Ns with Barton 2500+ and 2 x 256mb of Crucial PC2700 @180FSB & Fortron 300watt PN series PSUs. They use all onboard options and have never given me any problems.
You can use Riva Tuner to OC the IGP for ~6K in 3DMark which allows them to play BF1942 @1024 x 768 x 32bit with no issues and decent FSP. They make great little LAN rigs.
Regards, Szandor
Not the PSU. I mean, its an Antec, after all! :)
I found the problem by reading the product reviews again at Newegg.
Had to download the latest bios to disable "RAM pre-charge".
Once I did that, stable as a rock at default settings.
Not gonna bother to overclock this thing, the computer its replacing for the teacher is an old P-90, so its gonna seem LIGHTING fast as it is. :)
BB
