shuttle cooling?
Evanthes
hey all im owner of the shuttle computer in my sig...was wondering if anyone knows of a good way to cool it better then the stock fans...quiet ones also! thanks
Search through the SFF mods, plentt of ppl here are modding the cooling in them.
MD
Definitely check out the forum picture for ideas about cooling.
Otherwise, a lot of people have cut out the exhaust grill and that helps a bit. You can cut out the sides and maybe but in a 60 mm fan, or if you want to look slightly ghetto, externally mount an 80 mm.
