Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
-cut the rear honeycomb girll on the back of the case
-yes putting a more powerful fan does help the temps, but it will be noitceably louder
-imo: use a 80-92mm fan adapter, and mount the fan externally (exausting all of the air)...
thats in a shuttle? I just got mine.. I guess i should cut out the honey comb thing on the back.. Either way..
does anyone have any advice on how I can get the shuttle to run quieter?
I take it the main ICE fan should be replaced. And the PSU fan? or the whole PS? I have a Crystal ORB on my radeon, I don't know if thats making a lot of noise, i don't think it is. I'll take it off if I have to. If anyone's got any tips, it would be appreciated. The noise this thing makes is driving me crazy.. Thanks a lot.
i cut out the grill in the back added a 80mm top blowhole using 2 coolermaster LED Fans and with my 2500 Barton @ 3200+ 400mhz oc I idle at 32c on the proc 30c case and 31 on the psu and load is 45 max on proc 35 case and 37psu !
ok. so maybe it was my crystal orb.. i just checked.. that thing was actually touchin the side of the case. that can't be good. haha. aight.. what are the suggestions on replacement ICE fans? Thanks.
