Shuttle AN35N SPDIF Add On?
FatSean
Does anyone know how I can get my hands on a SPDIF add on card for the Shuttle AN35N? The only thing I can find is this:
http://us.shuttle.com/specs_access.asp?pro_id=323
It's listed as an add on card for those stupid shuttle mini pcs. It doesn't list which Shuttle mobos it supports. Anyone know if this will work on a AN35N? Or where to get the real shuttle spdif add on for the AN35N? Thanks!
The AN35N Ultra has SPDIF, you don't need an add-on card, there is a header on the MoBo - Page 10 of manual, bottom of the board "SPDIF Exten. Header - JP7" also explained on page 40 with pin IDs.
All you need is the PCI bracket, NewEgg used to carry the Biostar version for $8.00 delivered but don't appear to stock it anymore. Try looking through Pricewatch or Google.
Soyo make a sweet one for $20.00 that also includes extra audio out connectors so you don't have to give up your mic and audio in jacks to support a 5.1 channel sound system. The Soyo model also has both optical; and coax SPDIF in and out jacks.
http://shop.soyousa.com/customer/product.php?productid=293&cat=&page=1
Regards, Szandor
