shuttle + 64 bit drivers
vage
Does anyone know if shuttle is going to be making all of their drivers for sound, USB 2.0, etc.. in 64 bit format so that us with shuttle PC's can use the new windows 64?
thats up to the companies that make those technologies, Shuttle doesn't have anything to do with them. They simply put it together and sell it. Support for XP64 is rather lacking right now, but it will get better as the os catches on.
Most review sites (CNET, for instance) say that most, if not all, companies should have 64 bit drivers up by the end of the year
I would guess that depending on the chipset used in the shuttle would tell you if 64 bit drivers were available. I'm not sure which model shuttle you are referring too, but in the case of my shuttle model the SN85G4, and the SN95G5,(which both have nforce 3 chipsets) I should just be able to download the nforce drivers for windows 64 bit, and be done with it. Not 100% but pretty dam 99.9% sure that is all I need to do, that and 64 bit video card drivers which Nvidia has too. So I should be set for the jump to 64 bit windows.
