Shutting down computer for a few days for WC installation.
Lee Enfield said:
Good luck and remember to do a LEAK TEST.
When you leak test do you just put in distilled water, or do you add all the water plus the anti-freeze and stuff?
i think with additive it;d be a better idea... just save it when and if u have to empty the loop due to leaks. Besides, additives leave better marks than plain water... easier to notice leaks :D
it just means that your run it for a bit (longer is better) before putting the parts in.
Just turned it on after running the water lines only for 1 and a half days and.............................
BZZZZT!!
Not! Glorious quiet computing.
lol, I was gone anyway so I just let it run. Seemed good, so here I am. Now its time to close it all back up and hope it never fails.
i remember when i first installed my watercooler, i leak tested for an hour before the anticipation got to me and powered up my system.
he'll be back up and running before the end of the day boasting about his new low temps :D
I can't tell if you're being sarcastic or not, but I'll point out that the guy in question actually made his return about an hour and a half before your post.
So yeah, 31 degrees celsius at load non overclocked, but totally silent. Pretty kick ass.
