Shut Off Valves for a WCing setup
videogamer323
I need some sort of shut off valve to turn off the flow from my custom WC box to my rig so I can move it from point a to b (mostly lan parties). I will be using the new Apex kit. I can't seem to find any valves that I could use.
THANKS!
Im looking around that site any ones your would recomend over others? and I want the 1/2" barbed right.
Make sure you get the shut off type not the straight thru ... otherwise when you unplug your coolant will drain.
Yes you can do those in-line or panel back of case mount one part of it.
I want Item Number 60733 and 60740 to go with my kit right
sorry just wanna make sure before ordering
Thanks!
Heres the ones i am using for my custom WC case.. just installed them last night. They shipped the order fairly fast.
yeah, i got started on my 1st mod project!!! its very green!!! i have a bunch of pictures i will share... but going in for hernia surgery so the install of the WC stuff, and the build of the custom will have ot wait a week!
Bio Hazard, do you have any more shots of that external cooling box ? Looks really sweat!! :cool:
Good luck on the surgery. I won't lie, the surgery caused me excruciating pain for about 2 or 3 days, but after that, it was sure nice to not have that throbbing abdominal pressure. I was in the gym on day 5 :D
I've had 2 of those damn things fixed, last one was this past Christmas, I was in and out of the hospital in the same day. I was working on my systems after about 3 days due to really good pain meds............. :eek:
So which parts are needed exactly? Bio Hazard how much restriction did the valves introducce in to the loop? I'm planning on using an Iwaki md20rlt, swifty storm and maze4gpu block maybe 2. Thanks for any help or guidance you can offer.
-Brandon
