Last week my Shure E3c were delivered. I got them for $119.95 from compuplus.com.
First think I noticed was a problem with my Rio Carbon. The earlier Carbon's had a problem with headphones with metal plugs picking up noise from the metal case. One paper washer later, problem solved.
Second thing I noticed was that after several hours my ears hurt. It took me a few days to get used to them. I also don't try to wear them for four hours at a time anymore.
I'm getting the best results with the soft gray flex tips. They don't block out as much outside sound as the clear flex tips or the foamies, but they are far easier to put in and much much more comfortable. My foamies are also different lengths. One of them is a little too long to comfortably put in my ear.
They sound great. I don't know if it's a placebo or not, but at first they didn't seem to have that much bass, so I eq'd them heavily. Then a few days later I was listening to a track, and thought, "Oh hell, listen to that kick."
My current eq settings are about +5 on the deep bass, +0 on the mid bass and the mids, +1 on the mid highs and +2 on the high highs.
Pro's:
Clean accurate sound, just a little strong in the mids
Portable
Warranty
Con's:
Comfort
Foam tips not cut right
Cable is about a foot longer than I like
Probably should have listened to the e2c's first to know if the extra $50 is worth it...
I'm going to stick to my Senns at home, but these will work for exactly what I wanted them for - better sound for my mp3 player.
-dB
Pro's:
Portable
Warranty
Con's:
Comfort
-dB
