JosiahBradley
- Mar 19, 2006
So I just recently got a PNY XLR8 1080 Ti and the thing is amazing. Gaming at FPS I've never seen before. However there is always that voice in the back of my head to push it further. I started to overclock the card and immediately hit a power wall. The card runs comfortable at 70C at 2Ghz with no voltage modification and at 2.1Ghz with +100mV(? Afterburner labels it as % but I'm used to it being mV in AMD land)
The problem is that while monitoring performance GPU-Z continuously says Pwr throttling as the card sits around 120%. So the question is should I unlock the beast as I feel like I have a good sample or am I already hitting clocks high enough that I won't gain anything modifying the card? Also is it dangerous to feed the card more power as long as cooling is adequete and voltages stay sane? And can I undo the mod if needed? I've seen videos on how to do it and what it does but not many claim it is dangerous. But was hoping some of you guys and gals had experience doing it already.
