Shroud
catarrhine
Has anyone seen a shroud that looks something like this?
[/URL]
I have an innovatek dual 120mm rad that has a shallow shroud on it.
The 120mm fans connect directly to it; the easiest way I have found to attach the fans is by using plastic push-pins (rivets). I want to increase the distance further, but I need to be able to attach the pre-existing rad shroud to the new shroud, and then, attach the fan to the new shroud. I dont want to drill through the fins, and I want to avoid cardboard and duct tape :)
All help is appreciated.
cork automotve gasket material? probably doesn't rank much higher than cardboard, though.
A radiator like that one doesn't need a shroud nearly as much as a hc does. Personally, I wouldn't worry about it.
Hey guys, thanks for the replies. In lieu of finding exactly what I want, I think I'll try Sideroxylon's suggestion and won't worry about it :D
