mich43L said:That's Polypropylene, the shiny kind. It is inferior compared to Polyolefin heat shrink tubing. In addidion to be things you mentionedm, it is also less flexible. But I still use the stuff in part because I can't find the Polyolefin heat shrink in a smaller diameter (Lowes Home depot have only large diamaters) and I feel kind of stupid buying the stuff online![]()
phasmatis_nox said:I use the barrel of my soldering iron most of the time. You can actually have the haetshrink touching the barrel without a problem, just make sure you keep it moving, as soon as it shrinks down, move to another area. It takes less than 5 seconds. A candle/lighter works in a pinch. but the ideal way to do it is using a heat gun.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=35776
