show me your...
burnin8r
fan controllers.
I recently bought a LanboxLite which has 4 fans (one intake and three exhaust).
I am debating whether to go with a 3.5" or a 5.25" panel, so show me what you got.
thnx in advance.
2x CoolerMaster CooldDrive 6.
Uses software (via internal or external USB), or the hardware buttons to control three 3-pin fans (and it's own internal fan, to cool the 3.5" HDD it holds), and monitors 4 temperatures via probes that can each have their own high-temp warning. Also available in black. $15-50, depending on vendor/sales.
didnt have everthing pluged up when i took pic
thnx for the pics. I decided to go with a 3.5" fan controller because the Lanbox has stealthed drive bays and I didn t want to add something that would make the front too "busy".
I ordered the RH-35 SE from performance-pcs.com. Unfortunately its out of stock and they don t tell you this until after you order. So, the vertical 3.5" slot will take on a few silver knobs and I am relocating my hard drive to an unused 5.25" bay. Anyone know of another place that has the RH-35 SE ? Or possibly some other decent looking, well built Rheobus that fits in a 3.5" drive ? I don t want a cheap $5 ebay fan controller.
