In all the pictures [H]ers have posted, fans are mounted on the radiator itself. This puzzles me: doesn't this create a huge dead spot in the radiator, the size of the fan's spindle? So therefore shouldn't fans be mounted away from the radiator to maximise the cooling?
For instance, if you have a Corsair H80 and a case with three fan mountings - top at back, rear CPU, and front bottom. instead of mounting the radiator and fan on the rear CPU blowing in or out, wouldn't it make more sense to close off the rear CPU mounting and mount the radiator in the top one and the fan at the front bottom blowing in? Or mount the radiator at the top and the fan at the rear CPU and create a duct to the top fan? Sure you're getting the same volume of air, but you're increasing the cooling area of the radiator.
