I'm using the Creative X-Fi XtremeGamer Soundcard and was just wondering if I should disable the onboard sound in the BIOS settings? I have heard (not sure if this is really the case or not) that it helps with performance when using a soundcard instead of the onboard and prevents less issues? If I should do this do I even need the onboard sound drivers from the motherboard installed?
