Wolfdale75
- Jun 17, 2010
Hi Guys,
I've got an Intel Core 2 Duo E8600 running at the stock speed of 3.33GHz, i.e. nothing is overclocked.
On idle and a newly-switched-on PC, the BIOS reports that the CPU is running at 54 degrees.
That seems pretty hot to me for an idle CPU. I would have expected 39-41 degrees.
I'm worried my CPU is going to overheat when I play graphic-intensive games like Mafia II.
Recently I had to reinstall the giant CPU heatsink on a new mobo. Instead of applying new Arctic Silver, I just used the coating that was already on the CPU/heatsink. It looked sufficient enough. Do you think that was my mistake?
Thanks for your good advice. Cheers!
