This is from a fairly new Win 7 Enterprise install. I run Firefox 3.5.3 with noscript, and just installed and am scanning with the MSE beta. Everything that looks bad was in temp files, but I am still worried. Should I reinstall Windows, or leave it as it is?
Also, does anyone know if I can reinstall with my Enterprise trial, or do I have to register for a new copy?
Malwarebytes' Anti-Malware 1.41
Database version: 2857
Windows 6.1.7600
9/25/2009 5:16:35 AM
mbam-log-2009-09-25 (05-16-35).txt
Scan type: Full Scan (C:\|D:\|)
Objects scanned: 395697
Time elapsed: 22 minute(s), 52 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Registry Data Items Infected: 1
Folders Infected: 0
Files Infected: 56
(No malicious items detected)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoActiveDesktopChanges (Hijack.DisplayProperties) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
Folders Infected:
Files Infected:
C:\Windows\Temp\bsxawjbbyc.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\bvnfbpptti.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\cpnvywdtdn.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\dhscxgvuiy.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\emiororxob.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\emxrqswkvl.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\etdceerorv.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\evirxluuro.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\feefqvueer.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\fuppvxkwnp.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\gwmyhhqpxt.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\iixmxiiqny.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\ipbcvtmtni.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\iqcdyyxvet.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\iuqpovmssx.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\jmkxnmvtwe.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\lrmxqwerct.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\noivembrhx.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\nvdeferxnu.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\oikvorptcr.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\onwetpouyu.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\oxelwnbici.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\pdnqxudtbi.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\pdrbpixxtc.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\pixisqyrur.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\pmdxseunxn.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\pnfxpbqkiq.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\ppttpxmsei.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\pttnqbejot.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\qmmcjnokxd.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\qvpgpmdxpu.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\rfiuphmpcx.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\ritpxcdmbr.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\rmcctimecn.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\rrsxieievx.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\rxwlfxoxqy.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\seninqtcqd.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\sfqeedrcxc.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\sgrvbuwwin.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\sopmvxtsqu.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\svcptnfihr.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\ubrmfubunx.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\vbvxbnceey.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\vhrbvwotvc.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\vwjbhqbjrm.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\vygriniipe.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\weccmpxmel.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\xedrdxqlcc.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\xfvotdelxq.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\xqtwxtbbpj.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\yinppwbgdx.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\yueqwqqivb.tmp (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\~403E.exe (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\~4E3D.exe (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Windows\Temp\~7F51.exe (Rootkit.TDSS) -> Quarantined and deleted successfully.
C:\Users\asyork\Local Settings\Temp\_check32.bat (Malware.Trace) -> Quarantined and deleted successfully.
Windows 6.1.7600
Folders Infected: 0
Files Infected: 56
Folders Infected:
Files Infected:
