I was at the same stage as you but I said screw it. Is $100 and 5 extra fps in crysis really going to shatter the earth and change my life? I have better things to spend my money on. Though I'm not one to upgrade, I just build new pcs every 4 years about. Right now, and in the future (from what I can see), I'm not going to need any more GPU. Do you really need the extra performance or do you just have that itch? If its the itch, just ignore it. Also, if you have $100 that you absolutely cannot think of a better way to spend, then 100% go for it.
5fps wouldn't be enough to justify $100 for me...
but it's your money.![]()
It'll look like shite.Just while we're on the topic of res, how much worse does 1440x900 look on a 26"? You think I'll really give a damn if I can't play at 1920? The clarity is great on a 19, and if it remains decently so on my bigger monitor, I see no reason for upgrade.
Keep in mind you also have to pay to ship the cards both ways. Then you will be without a video card for a while. The Ati cards will be droping in price like crazy soon and Im sure that will push Nvidia to do the same, probably by the time that you get the card that you paid for. Just hold on to that and upgrade when you will see some real gains for your money.
What makes you believe that prices are about to drop big? I've not heard this anywhere, nor do I have any reason to believe it.
I just stepped up from a GTX 260 SSC to a GTX 285. I wanted the 285 SC but you can't step up to it, only to a regular 285.
Put it this way. Can the GTX260 handle 1920x1200 on your setups adequately? For me "adequate" ensues at least 40fps. I don't need 100fps like some people.
My stepup runs out in 15 days and thinking of doing the same. You think it was worth it? My cost will be ~ 120 after shipping.
