Should I step up EVGA 800GT
calikool
Personally, as my step-up ended well before the arrival of the new 9xxx series, I decided to simply step-up to the G92 GTS. My GT wasn't a solid overclocker and thats one thing I built my entire system for so it kind of let me down. It was not stable at 2GHz memory at all and I've heard the G92 GTS is an overclocking monster. Figured, what the hell?
That said, if you step-up ends in 60 days, you have a much better opportunity to see how the new series pans out. If I had another 60 days, I would definitely be waiting until the last couple days of my step-up. Hope this helps.
Also, A3's usually ship with a game such as Crysis or Quake Wars. While AR's are simply the base without any extras.
I just recently bought the EVGA 512-P3-N802-AR GeForce 8800GT Superclocked 512MB 256-bit GDDR3
I did see that newegg had the EVGA 512-P3-N841-AR GeForce 8800GTS (G92) 512MB and the EVGA 512-P3-N841-A3 GeForce 8800GTS (G92) 512MB. I am not sure what the difference is on these cards and how much improvement I would see.
Should I step up to one of these cards in the next 60 days or will the 9xxxx be worth the step up? Comments welcome.
I did it myself as the cost was minimal and it was the only choice I had or was going to have at the time. You'll see some performance gains, but not tremendous, but it also overclocks well for most. One of the biggest advantages is the dual slot cooling desgn. I was very close to upgrading the reference cooler on my GT, but then I did the numbers and figured a new cooler was going to cost me a little more than half the cost of Stepping-up to the GTS 512MB. So I figured what the hell. Also as silasbear said, you can only step-up to the -AR card without Crysis.
Now should you? Of course not. You have the opportunity to Step-up to something which "may" be noticeably better where as I did not. Wait till the new 9800's appear and see what they've really got under the hood. You've got 60 days to find out so don't rush it and if you still wannt to upgrade to the GTS 512MB later, the prices are going nowhere but down.
Edit:
Skizzled, didn't read your post till after I made mine. Looks like we had the same experience.
