I have an Aspire QPack case, and just bought an antec TruePower 2.0 PSU from a local Best Buy.
I tested the components with an old CD burner (a Cendyne that is a few years old) and it looks like the power plug for the optical will fit if I fix the wiring, but I don't want to mess it up enough so that it can't be returnable. I tried a Liteon CD burner that is a couple of years old and its the same size as the other CD burner.
Should I just return the full sized PSU and try to find a smaller PSU, or just hope that the current liteons are smaller?
