Should I replace my Mobo?
VladDracule
I'm currently running this Mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131981
The issue im having is my video card died and I'm going to be getting a 1080 GTX. Im wondering if this mobo is still decent, and if i should upgrade if i want to overclock at all. Chances are I'll also be getting a 1440p gsync monitor as well, I believe my CPU/RAM are still good enough, but its the mobo im unsure of what recent strides have been made
the board you have is fine. No sense in upgrading a motherboard on an old platform. What CPU are you running anyway?
IMHO, putting a 1080 in that mobo would be like putting a 5.7L V8 Hemi into a subcompact.. yes it could be done, but why bother with such overkill ?
You will be putting a current-gen GPU into a mobo that is 4 gens old (soon to be 5) along with a CPU that is also several gens old. Again, yes it can be done, but why bother with such overkill ?
Makes no sense to me.....
really depends on his resolution, at higher resolutions he won't be bottlenecked by the 4770 (especially if that's a 4770K with a good OC)
Blatently ignorant. Theres abit more performance in the newer stuff, but not enough for that comparison. This is like putting a 6.2L Hemi, in a car that originally had the 5.7L.
That board is PCI-E Gen3 compliant, and the CPU is fine.
Go ahead and upgrade.
