Should I Or Shouldn't I
JKownz
I have a DFI Nforce 3 mobo. I was hearing that if you put close or max memory on that mobo it will slow down. I have 2 x 512 stick in it now, but i want more for my video editing and multimedia things and maybe for some gaming, and on the box it says 2 Gigs of ram max runing on DDR 400. So would i still get an increase if i put another 512 in it or will it decrease?
I'v got a amd64 3400
And sticks that i have now are running at 3200 speeds
I've got a Neo2 (nforce 3) board. and with 4 sticks of ddr 400 in it the default speed is 166 (would have been 200 with 2 sticks of 1 gig instead).
Not sure if that is with all nforce 3 boards or if it's just with the msi neo2 platinum. something with all 4 memory slots filled with double sided memory sticks, the speeds drop rto the next lowest level. now if i new this i would have got 2 sticks of double sided ddr400 and 2 sticks of single sided ddr400.
bank 1 = double sided ddr400
bank 2 = double sided ddr400
bank 3 = single sided ddr400
bank 4 = single sided ddr400
this would run at 200
switch out banks 3 & 4 with the same double sided as in 1 & 2 and it is running at 166.
I got 3 socket dimms. right now i got 2 runing at 200 each. if i add a third it will prob split into a even 400. I know that already. I want to know if i still will gain a performance increase when i get close to the max memory the board can handle.
