I should be getting my Apex Extreme kit in this week and I dont want to cut any corners on this project. Would it be a good idea to lap the Storm block or do they usually come with a good enough surface that lapping would be pointless? Has anyone actually lapped a Storm and did it help at all?
As for how to lap, let me get this straight:
1) use a hard flat surface to put behind the sand paper like glass. Or would it be better to lay the sand paper on a flat hard surface, and rub the block over the sand paper?
2) wet the sand paper, and start from 400grit or so and go up until you are happy
3) rub back and forth, or in a figure 8, not sure on this one...
Thanks in advance
Thanks in advance
