Should I get new fans?
If you get an fan bus and slow the fans down, the sound drop by almost half. I did this with my 92mm Tornado's.
I don't really want to mess with the speed of my fans, or download additional hardware.
I just want fast, silent, and stable fans. What should I get?
Should I get a new heatsink fan too?
I looked up the fans you have and they have the same dba level ( or loudness) as the one you found on new egg, so I wouldn't change them right now.
As for heat sinks that are quiet the zalman cnps700a-cu is virtually silent.
Ps never glue an heat sink to a CPU use a heat sink compound like arctic silver5 or arctic silver ceramique thermal compound.
