I'm looking to SILENT up my computer, and do a little hobby work on my case.
Currently my old Enermax PSU is starting to get loud, b/c the temps in my case higher and the fans are spinning full till.
I bought a new Thermaltake Butterfly PSU, which is supposed to be silent, it's been sitting on the floor for one month now LOL, waiting to be installed.
Now I also want to purchase a water cooling system, I was planning on the original Kingwin ACW-1 system which is VERY similar to the new CoolerMaster recent release.
Does anyone have any experience with the Kingwin AS-3000, is it silent? That's the most important part, I know there is a adjustable fan speed, and I will probably be running it on the 'lowest' setting.
My CPU is 2500 Barton core, and I'll also be using the GPU cooler to chill down my 6600GT
Do you guys reccomend removing all my case fans after I install the new PSU and cooling system, to reduce the noise?
Thx lots!
Thx lots!
