Should I get a new case?
cslogical
I have a Cooler Master Wavemaster. Seems to work fine but I have ordered new cpu/mobo/ram and maybe a new case.
I was just wondering if it's a good enough case to stick with or get a new one.
Cooling wise the Wavemaster is not the best. If your new components are going to be producing more heat than your old ones I would consider a new case. Otherwise keep the Wavemaster if you want, as long as it adequately cools your components.
i'd say one of the biggest downsides to the wavemaster is the use of 80mm fans throughout.
other than that - it's a pretty solid case.
I don't overclock and I'm switching to a Intel Conroe setup. I'll probably just stick with what I got.
PLmatt91 said:
Post pics of your current one.
Don't have a camera but it's a black Wavemaster. I keep it pretty clean as inside I have 1 hdd, 1 dvd drive, 1 soundcard, 1 wireless card along with mobo and 1 vid card.
