Should I build it?
Lysam
The purpose of this post is to see what you think about this build, and if you believe I should wait for a while or go ahead and build it.
Gaming and work
$1000
3) Where do you live?
Chicago
Motherboard
CPU
RAM
Video Card
Hard Drive? Haven't decided if it is worth picking up a solid state drive or just using my current drives and possibly getting an external in the future for more space.
My current plans are to purchase:
$179.99 - MSI P67A-GD65 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
$99 Minus $20 for newegg combo - G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
$220 - Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
$30 - COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler
$185 after MIR @ Amazon - XFX Radeon HD 6870 1 GB DDR5 Graphics Card HD687AZNFC
PSU:Rosewill Xtreme Series RX850-S-B 850W
CASE: XCLIO A380BK Fully Black SECC 1.0mm thickness ATX Full Tower
2 x Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM SATA 3.0Gb/s
Windows 7 Ultimate upgrade from Vista (I will have to install both =( )
6) Will you be overclocking?
Yes
22" 1680 x 1050. Might upgrade or grab dualies in the future but not now.
Soon, unless a significant price drop or quality improvement would be in the near future. Really the entire purpose of this post is 'Do you think I should wait'? I will likely buy the parts this week unless you think waiting a few weeks or months would bring me benefit.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Crossfire support is the most important. USB 3.0. Multiple SATA ports since I currently have 2 drives and will probably be adding another one.
64 Bit Vista, going to upgrade to windows 7 64 with my student discount
I am looking for price/performance ratio, and my primary concern is the newness of the 1155 motherboards and sandy bridge processors, as well as the possibility of the new AMD bulldozers. Also if the video card is worth grabbing at that price, or if I would be better off waiting and purchasing another card. If you believe I can gain significantly by waiting on the motherboards or processors for a few months than I have no problem waiting.
I have no urgency, but I want a new system because my motherboard is slowly crapping out on me. I have an old E8400 and a Radeon 4850, so I am going to just upgrade my system rather than purchasing an old board.
So do you guys think I should pull the trigger or hold it off?
Why not. I would pull the trigger considering your current mobo is crapping out. It would be a pretty substantial performance gain from an E8400 Dual Core to a 2500K Sandy Bridge Quad Core. There's a Microcenter in Chicago and it's selling the 2500K for $199.99 in store.
Holy moly its down to 179.99, 197.55 with tax! I am almost tempted to upgrade to the 2600K, but I am sure most of the games I will be playing won't support HT anyway.
Any comment on the motherboard situation? Would I be better off waiting until more sandy bridge mobos came out?
Holy crap! It is $179.99. Damn that's an awesome deal for the performance you're getting. Upgrade man upgrade.
Well I pulled the trigger on the processor, thanks!
I might wait until there are a few more motherboards that are even purchasable before I go with the MSI one though.
