From a lot of testing I see that "side mounted" cpu coolers are getting most of the editor's choices... But I think that this might be at the expense of motherboard chipset cooling. I have a coolermaster right now, but the temps aren't as low as I'd hoped... Below are some pics of my case configuration. I'm hoping some of you may be able to suggest whether I should be using a "side" or "top" mounted fan assembly for my processor. Thanks! (BTW, when I get my new mobo I'll be cleaning up the wiring mess).
Thank you!
Thank you!
