Should I be concerned?
silk186
I'm not having the best PC day.
I'm trying to set up SickRage + Plex on my desktop as well as a number of series.
I've been working on this the past few days. This involves lots of downloading and moving large amounts of files around. Software is in C:\, Downloads are in D:\ and processed files are in F:\
This is not very easy to set up, which is fine because I'm enjoying the process.
The issue is that today I was having trouble with uTorrent and video playback, and the computer wouldn't shut down. uTorrent wouldn't close even with end process tree. I was forced to do a hard reset reinstall uTorrent.
Things seem to be getting better. The reinstalled uTorrent isn't locking up my computer. The reason I was trying to kill uTorrent was that I was having trouble accessing my D drive. If I tried to move around in it with explorer, explorer or windows would crash.
This got me thinking about the health of my drives. I know about CrystalDiskInfo, and I've attached screen shots. Can I get some feed back on if I should be concerned. I'm a PhD student, so while I would love a shiny new 3-4tb drive I don't relish the thought of paying for one.
1TB drives are cheap. That one is on its way out. Might be a few days, could be several months. Really up to you if it's worth the potential aggravation to save ~$40... or whatever a 1TB Seagate costs these days. :)
Are both drives dying or just the one on the left?
Nothing of much importance is on the drive, how long does it have Doc?
I'm in the UK, on a budget. Want to go bigger if I need to replace it.
1tb drives are cheap but not the best value.
What drives are being recommended at this time?
I would probably install some games on it and use it for downloads and media.
**wait, i realized i have two photos of the same drive
Unless I'm mistaken, you've provided a screenshot of the same drive twice.
In my opinion F: is possibly okay (although it can't read 6 sectors it wrote/ lost data). D: is most likely dying with 969 reallocated sectors and 21 sectors with lost data.
Edit:
You may want to backup F when get a new drive for D: and then test F: as well. I use a 4 pass read / write badblocks on linux for testing all drives. A 4TB will take over 50 hours to complete this test. If you are not comfortable with linux a few full formats followed by looking at the SMART will be a reasonable test.
replace those drive soon or would regret...
I have one 3TB Seagate with the same symptom as your D Drive.
the HD always randomly dropped from raid.
smartctl(under linux) warned on healthy status
RMA it if still under warranty or backup your data to your new HD
If I only had one... I RMA 10 to 20 of these each year although the warranties are up on most of our Seagate drives. That is except for the 20 or so constellation ES.3 drives I purchased this year.
So... I was just offered editing work which should cover most of the cost of the drive...
Seagate Barracuda 3TB ST3000DM001
Toshiba 3TB DT01ACA300
WD Caviar 3TB WD30EZRX
Secondly, anyone from the UK...is amazon prime the best choice, should I be waiting for December for a sale? I don't have anything important on the drive.
I would rank them in reverse order from what you listed so WD Caviar 3TB WD30EZRX would be the drive to get.
Interesting, given the the WD is a green drive I thought the 7200rpm Seagate would have taken the recommendation.
The WD drives seems to be a little old...2010? are any new budget 3tb drives expected to come out any time soon?
I would like to point out that the 1TB drive reports a maximum lifetime temperature of 58°C.
That is quite hot and if the drive operates at such temperatures for extended times, it can lead to its death.
That is an old drive, that has been through a few builds.
I don't think it ever goes over 32 in the case it's in now.
so far... one 3TB this year.
with in 2 years, 10 HD were already RMA, Seagate and WD HDs :D...
still loves 7200.10 ST3500630AS 500Gb, those HDs just keep working and working :D. I think the warranty was 5 years. all already expired!, those drived moved from Hardware Raid to ZFS (ZFS on Linux under centos 6.X) in 2012.
constellation HDs are a way way way..........above my budget :D
I am thinking to buy white lable HDs from ebay, the seller give 1 year warranty......
any tthought?
